Vts switch removal
ericcarr2000
Ensign
Vts question
Ever since I bought my 01 sea doo rx di, the trim hasn't worked on it so I decided to pull the vts motor and found a bunch of water in it and quite a bit of corrosion in it. Surprisingly enough when I hooked it up directly to a battery it did turn. I decided to replace it anyway. At this time I decided to just go ahead and replace my vts switch on the grips. What's the procedure to replacing it?
SeaDooSam
Awesome! How do you like the DI. I have only heard bad things about them.
jbcurt00
Might post just how you did remove and replace the VTS in the grip Eric, that info might help someone else.
