Want to find or build a top for my boat, any ideas?
jrmarsh
Okay, before someone says "Hey idiot, you can find bimini tops here on the site" I just want you to know that I already know that. So, I have a 1963 Glastron Gulfstream V194 and want to either buy, or make a hard or soft top for it. Obviously, it's kind of a hard thing to find. I do have a soft top but it's in very poor condition. I just want a small portion of the boat where I can get out of the elements and I want it to look good. I'm thinking about trying to build one but am not sure if it's a good idea.
Any ideas or pointers would be appreciated.
Thanks,
James
ziggy
Re: Want to find or build a top for my boat, any ideas?
i've no idea how to make a hard top, but i sure do like mine that's oem. + it's a sliding hardtop too.
a couple of pics, maybe ya can copy the idea over to your boat??
as to how to make one. mark42 did up his boat real nice. http://www.shareaproject.com/pages/projectTut,p,386,00.html a home made hard top.
5150abf
find a local upulstry shop and see if they can make you one using your existing frame.
island mike
Try honeycomb,
Its a lot of work but worth it..
Good luck.
You know how to sew? Have an industrial sewing machine? If not, I would suggest a marine upholstery shop. I know how to sew and have an industrial machine and I had someone else do the last one. Its a lot of work and more than you would first guess.
Texasmark
I had a custom canvas shop build one for my Ranger Fisherman. I specified SS support members as I didn't want any problems at the speeds I planned to run with it up, and that was a mistake. SS tubing is much much heavier than alum and for most applications alum works just fine. I know you have your old members, but just in case you changed your mind.
HTH,
Mark
Texasmark
Back in the '65 time frame I saw one of those on the Gulf Coast. Seems the mfgr was using his head with the design... The slide out of the way function solved a lot of problems. I really liked the idea.
Mark
rivermouse
I also needed a little removable top for my boat and wanted it to look good, be sturdy and CHEAP to make,,Here is what I came up with....topper 005.jpgtopper 017.jpg
rivermouse
Bondo..It looks good . Mine can slide back to shade the back seat or forward to cover the front seat. Only mod I need is to make it lift up for easy access to the front when I first get in. The first time I used it I got hit by a strong storm with 60 mph winds and the thing stayed in place nice and tight.
