water/ fuel filters
tav1
when changing out the water/fuel filters ...other than buying the same one . how
would you know which ones to get ....thread size and seal. do most have the same thread size
I believe the thread pitch is pretty standard unless you have an odd ball. Most of the housing are pretty universal as well as far as seal size goes. Take a look at the underside of the housing and see if it has several groves on it to fit different size filters.
c hook20
if you are referring to a water/fuel separator, there are a couple different size threads. Get the part number off the one you have now. And why would you not want the same one??
There are two different size housings on the market
“Mercury” uses a 11/16 ̋-16* and “OMC” uses a 1”-12
The 11/16”-16 is the most common and fits most existing filter mounts
