water in lower unit in gear oil
dannysmith
i went to change gear oil and it came out white and water also came out what could it be do they make white gear oil i have a 1976 25 hp evinrude
dew2
Re: water in lower unit in gear oil
You need new seals and drain screw washers.
kenmyfam
Could be as simple as replacing the drain screw seals. I would check that first before ripping into anything else.
boobie
If the drain screw seals aren't bad, have it pressure and vacuum checked before taking it apart. That way you'll know exactly where the leak is.
