'84 898/2bbl.......I just changed the plugs..........every plug had water on it. Where do I start?
B Bass-by-you Seaman Joined Sep 14, 2009 Messages 62 May 23, 2012 #1 '84 898/2bbl.......I just changed the plugs..........every plug had water on it. Where do I start?
tpenfield Moderator Staff member Joined Jul 18, 2011 Messages 19,087 May 23, 2012 #2 Re: Water in the cylinders? Now what? Spin the engine with the plugs out to get the water out. Put some fogging oil in the cylinders. Run a compression test I would check the intake manifold for cracks That would be a start
ziggy Admiral Joined Jun 30, 2004 Messages 7,473 May 23, 2012 #3 Re: Water in the cylinders? Now what? i'd start here. specially the part about saving the engine. this is a good read too. it's where the first link came from.. item #22 from the adults only sticky thread at the top of the i/o forum..
