Water leaking from Impeller housing
clearbluewater
3.0 GLP-E
Water seems to be leaking from this hole under the impeller housing
It was leaking so I decided to change the impeller and the oring but looks to still be leaking
What could be causing this and how to fix. Thanks.
Andrew W
More than likely the seal is going bad. Noticed mine was slowly dripping this weekend as well. Going to rebuild it with a new bearing and seal.
Rebuild kits and replacement pumps are inexpensive if you look for the Johnson pump directly. Sherwood also has the same pump.
