water leaking from lower unit? 2002 yamaha 2 stroke 115hp?
duff
just replaced all the parts to the water pump except the plastic housing. what have I missed that would be causing this water to leak from all these places? or is this normal for a yamaha. This is my first yamaha motor but still seems odd. I do get a solid stream out of the pee hole.
thank you in advance for the help.
Duff
These are not " leaks "-----Just water draining as per the design of the castings.
duff
well that is reassuring as i am new to yamaha motors and don't recall seeing that on my mercs. thanks for the info. Duff
