Water not pumping.
bmac417
1999...lsr 2100. I put a new impeller and thermostat in last year. It ran great. Fired it up today in driveway. Won't pump water. Impeller stuck? Thermostat suck?Not spinning? She got a Lil warm before I noticed it.
Ayuh,..... How are you feedin' it water,..??
You might need to prime the pump, to help pull the water up over the hill from the drive,....
'n if the pump was dry, you mighta smoked the impeller,....
