Water pocket cover rubber seal
Bass-by-you
First timer tearing down and servicing an alpha 1. On lower unit a water line goes up into the gear housing and slips into a rubber seal. This rubber seal is about 3/4" high, 3/4" diameter and about 1/4" wall thickness. Manual #6 (driveshaft housing- 3A-23) calls the item simply a rubber seal with an all important alingment embossment on the side of it. I have looked all over the exploded drawings on iboats and have just not been able to find it. I just need the part number so I can order one.
Thanks guys
Bass-by-you
Re: Water pocket cover rubber seal
Bond-o....thanks for the reply. Do you know if this part has the embossed nipple on the side of it. Hard to tell from the exploded view.
Thanks much
Ayuh,... The picture is of a Gen.II....
Parts are ordered by Serial #s...
ErieRon
Try this P.N.; 26-36557
You still really don't know what year drive you have, right? That P.N. is for an Alpha on a 1982 model 898:rolleyes:
Bass-by-you
ErieRon..thanks for the reply. I have confirmed that I have a 1984 898 but I do not know how to confirm the model year of the alpha. I have reviewed the service manuals for the alpha 1s and they appear to match my unit? The pic you posted is exactly the piece I was looking for and I will order that part.
Thanks to both you and Don for your help.
Bass-by-you
Thank ya much...just looked it over...my unit is the '84 model outdrive....that's a big help!
Bass-by-you
Sorry Bond-o....mulitasking here and got crossed up.:redface:
ErieRon
Uh-oh...a little free advice rivalry...:D
