Water Pump Gasket Sealant
yt
Can I use Permatex #3 aviation in place of the OMC Gasket Compound on the water pump and shift cover gaskets?
Also I saw one guy online in a video using super glue for the o-ring type seals instead of 847 adhesive. I'll try to find the 847 but in a pinch?
Re: Water Pump Gasket Sealant
I used silicone to glue the orings into the water pump cover and base. The Aviation was used to stick the gaskets to the waterpump. Grease on everything else.
boobie
Yes......Permatex # 3 will be fine but don't substitute the 847.
yt
Having a heck of a time finding the 847 locally. Don't feel like waiting for and paying for shipping. Not many marine dealers around here and West Marine doesn't even show it on the website and that's the only local marine dealer. Otherwise there are auto parts stores. Closest I find is 3M yellow Super Weatherstrip and Gasket adhesive which I think is 3M 1300.
boobie
Give the 3M 1300 a shot.
Where are you located at ??
yt
Thanks for the tip. Looking it up it appears that Quicksilver Bellows Adhesive is rebadged 3m Scotch-Weld Nitrile which is #847.
QUICKSILVER - Marine Parts & Accessories Mercury Marine MSDS 029-0302
Material Safety Data Sheet
PRODUCT : 3M(TM) Scotch-Weld(TM) Nitrile High Performance Rubber and Gasket Adhesive
NAME: Quicksilver Bellows Adhesive
PART Numbers: 92-16556, 92-86166 1, 92-86166Q 1
DIVISION: Mercury Marine W6250 W. Pioneer Rd. Fond du Lac, WI 54935
Good to know. I'll assume that the Sierra Bellows adhesive I can get locally is the same. I'm in Arlington VA just across the river from Washington D.C. A decent marine supply store is a ways away in traffic.
RogersJetboat454
Another possibility for getting a tube of 847 is to call your local Grainger supply, and see if they have it in stock. If not, they can usually get it for you overnight. Supposedly NAPA also carries 847.
