water pump HELP
rocket rich
well I'm back again still playing with the water pump which is new ( Impeller). I've taken this apart 4 times and it still runs hot and locks up. WHAT AM I DOING WRONG SOMEONE WALK ME THROUGH THIS...PLEASE ARE IS THE THERMOSTAT BAD AND WHERE IS THE THERMOSTAT??? HELP
Thermostat is found on top of the cylinder head.---Cover with 3 screws.---------If motor has locked up a number of times you may have done serious damage to a fine motor.------Did 3 of those 6 hp motors over the winter.
rocket rich
WHAT DAMAGE DID I DO ??? IT LOCKED UP 4 TIMES. CHANGED THE IMPELLER, SPARK PLUGS, FUEL PUMP, AND ALL SEEMS GOOD WHAT NEXT?
175se
Dumb questions. Did you miss the water tube? As post #8 stated water must be half up the leg. Is the keeper for the impeller in place?
rocket rich
the keeper is so tiny I can't see how it would do anything but I'll take it down again. missing the water tube maybe...
The T shaped drive pin does an adequate job of turning the impeller.------Folks asked / commented on the water level in your test tank.---No replies to that important point.
