Water Pump Replacement on 115 Merc.
75TowerOfPower
OK so I am going to change the impeller for the first since I have owned my boat and I was wondering if you guys always replace the housing as well as the impeller and wearplates/gaskets?
I see that there are two kits out there, housing and non-housing kits.
narvlebenoit
Re: Water Pump Replacement on 115 Merc.
If the water pump housing looks good and dont have any groves in it I would just change the impller and gaskets.
Moody Blue
Agree with ^^^^^^. Inspect the wear plate and S/S cup insert for ANY grooves or wear points. If in doubt, change them.
At the very least, you will need the new impeller and gaskets.
Jacket4life
What type of gasket goop should you use when doing this? Or none at all?
Jacket4life
No goop necessary. Oil the o ring in the pump base, as well as the driveshaft, so you don't tear up the driveshaft seal. Oil the impeller housing to make installation easier.
