Water pump tell tale
mercurymang
Hello. Haven’t posted in quite a while. Looking to replace the water tell tell on my 75 650. Anyone know a part number or where I might find one. I haven’t been able to come up with a part number yet.
The telltale is a pipe fitting on the block, a hose and a plastic fitting in the lower cowling. What do you want/need to replace?
mercurymang
The tell tale on this model is a one piece hose with a special end on it to create the tell tale. That’s what I’m looking for
OK, that is unlike the IL4/6 motors I had from that era. Did you check Crowleymarine?
