water shooting out from under motor
1983rinker
74 Chris Craft inbord motor. I started it up Monday and water was shooting out from bottom of motor. I think it one of my trans cooling hose. I payed my marina to winterize it. But I see no evidence of at all. I payed them to do it. The water was coming up from under the motor and shooting up and hitting the oil filter. Could a cracked block do this? Need help.
Re: water shooting out from under motor
Ayuh,.... Call the Marina, 'n ask if they leave the drain plugs out....
Any 1 of atleast 4 could be missin'....
1983rinker
For what I see there in
What do you expect to see? They don't look different just because they are drained and put back together.
Have you talked to the marina that winterized it? That should have been your first choice instead of a forum since they did the job.
