Waterproof Switches?
quinnf
I'm redoing the electrical wiring on my old Mako 17 center console. <br /><br />Anybody know a source for waterproof toggle switches?
SlowlySinking
Re: Waterproof Switches?
Hi, first check our sponsor, iBoats.com, then do a web search with the phrase "waterproof toggle switch", here's one site that came up;<br /><br />www.eastwoodco.com
arks
If you intend to use standard metal toggle switches, you can buy rubber boots that completely cover the exposed part of the switch. They screw onto the base and seal out the water. I used one when adding my engine preluber. As I recall, they were in stock at my local marine parts store. Maybe Radio Shack has 'em as well.
ericgj510
There is a company called Blue Seas Systems that makes a nice waterproof switch but they are kind of a flat rocker type and come lighted or not. They also have lots of other marine electical stuff.
Boomyal
Off the subject but Arks, do you have a name or a website the the preluber that you mentioned. I've looked for them b4 but the few I saw were quite expensive.
Boomyal
Thanks Ark: Yes they are a bit pricey. Never seen one using a pump b4. The ones I've seen used an accumulater with a solenoid valve. Turn on the key and the solenoid opens to release the oil held under operating pressure. While the motor continues to run the valve stays open which allows the accumulator to refill. When you shut the key off the solenoid closes trapping oil, under operating pressure, till you turn the key on again and the cycle starts all over. Boeing B-17s started using them in the event that the oil lines got shot up so they had enough oil in the accumulator to feed the engine until they could shut it down and feather the prop.. I've long been sold on the idea as I knew that most engine wear occurred within the first few seconds of start up. If I've had an engine that has not run for a long time I'd pull the coil wire and crank the engine till the oil pressure guage came off the peg but this kind of thing would be mmmmmuch better.
