Weber change to Holley
Stingray1961
I have a 1993 stingray zp. 4.3 mercruiser Weber 4 barrel I want to put the marine Holley in does some one know if it's a direct bolt in or do you have to change the manifold
depends on the holley carb. some are spread bores, some are square bores.
Me, personally, I would run a 2" spacer
also, changing from the Weber to a Holley wont gain you any performance if that is what you are looking for
Stingray1961
No Title
Well I personal don't like the Weber I had it rebuilt and I have been loosing power carb surges
