weight of a 25 2 smoke evinrude 89
saumon
Re: weight of a 25 2 smoke evinrude 89
you should stop smoking man...:facepalm:
...or use the proper oil ratio :D
115lbs.
boater121
i think itd be too heavy for my 12 ft fiberglass v hull
Look it up on nadaguides
Posting the same exact question minutes apart will not speed up a response :facepalm:
I merged your threads.:rolleyes:
steelespike
Probably; is but what is the actual length. 12 or a little over or a little over 11.
also what beam. What deepest part?How heavy?There are small 12 footers
and big 12 footers. I had a friend with a 14 footer that was so small it looked like a 12 even on the trailer.
