what causes sneezing, low rpm misfiring, and won't idle?
pcrussell50
this is on one of my v4 crossflows with an ordinary choke, not that newer quick start enrichment solenoid. it runs GREAT, at higher rpm if i can get it there without dying, but i can barely keep it running at 1500rpm--where it has an irregular miss, and occasional sneezing. i rebuilt the carbs, including changing the core plugs fairly recently. i did a compression test this afternoon and got:
128-134
125-128
as viewed from behind. i have not done a leak down test.
i'm seeking some guidance as to where to start my troubleshooting. i "feel" like it's a fuel problem, or an air leak or broken reed. i don't "feel" like it's electrical--but feelings aren't worth squat in a deterministic mechanical system.
i'm tempted to tear into the carbs again just to make sure--unless someone here advises me otherwise.
-peter
kodibass
Re: what causes sneezing, low rpm misfiring, and won't idle?
Most often a sneeze at low idle is one of the carb low jets dirty & causing a lean situation, the fact that you say it runs well at high rpm's would lead me to investigate the carbs low circuit area further.
Rebuild the carbs again and make sure you do a Lync & Sync (check the timing)....... I have seen a V-4 idle on one cylinder so the other part you need to verify is ALL 4 sparks at the plugs too.
Haffiman
Check engine temperature balance. Defective, one or both, thermostats may cause what mentioned.
