What gearcase lubricant should be used on Johnson and Evinrude Motors?
iboat2011
Hello,
I have one Johnson 1962 40hp and one Evinrude 1968 18hp motor and both are manual shift. The manual mentions OMC Type C lubricant for the lower unit's gearcase. However it is hard to find nowadays. I am just wondering if Pennzoil Marine 80W90 Gear Lube found in Wal-Mart can be used instead? If not, what other brands can be used?
Thanks a lot in advance!
Andrew
hidef
Re: What gearcase lubricant should be used on Johnson and Evinrude Motors?
The Pennzoil will work just fine.
rickdb1boat
The Pennzoil Marine 80W90 Gear Lube will work fine.
iboat2011
Thanks a lot for the replies!
I just went to a Super Walmart. All they have is QuickSilver Marine Gearcase Lube. I am wondering if it is ok for my motors?
Thanks,
Andrew
hidef
As long as it is either 80W90 or 90w it is fine. The Quicksilver gear lube is good.
Type C is for electric shift motors only. Any marine gearlube for mechanical shift motors is fine.
seahorse5
Hello,
Andrew
Type C is now called Premium Blend and is only recommended for the electic shift and electro-hydraulic shift motors.
For your "oldies" a marine 90 will work or you can use the newere Evinrude gear oils such as HPF-XR and HPF-Pro.
