What is my boat supposed to weight?
GA_Boater
Re: What is my boat supposed to weight?
Have you raised the bow and pulled the plug just to see if water or much water drains out?
Watermann
klawton55
Thanks for the links zoola and Watermann. I have tried lifting the front out and no water comes out. The tires are rated for 1870 each, so the are fine. Although the axles should also be upgraded. I am trying to do that soon.
So Alwhite00 you don't think it is worth taking the floor up to look at the foam at this point?
jbcurt00
I think Al was suggesting that you need to address the trailer capacity, asap, and that the boat, rigged & fueled, even w/out waterlogged foam, may be overweight for the trailer as it is setup currently....
emilsr
When that trailer was built, tires were probably the limiting factor in GCWR. A load range C tire with 50lbs of air (like you currently have) will carry more weight than the 32psi tires that came on the trailer when it was new.
Before I said you were overloading your trailer I'd want to know the rating of the axles.
Alwhite00
Well, I would not but I would probably do some exploratory drilling to see what I could find. Just FYI - I had a 1986 210 Sea Ray Seville mid cabin and ready for the lake on the trailer it was just over 5,600 lbs and that boat was bone dry - $hi+ adds up quick, I really don't think you are all that heavy.
I would address the trailer situation though.
LK
klawton55
Thanks for the input. I will investigate the axles and see if i need to install heavier ones. I do agree that things add up faster than one thinks and this could be the cause since it is not extreme. where exactly would you drill hole to see. if i drill in the floor how would i repair it? I will weight it again in the fall and see if it changed any although I will have to remember what was in it and what was not.
Alwhite00
Well, I am no expert but you could drill a hole in the stringers & transom (inside the boat) and look for dry wood, If it's dark & wet you have problems. Drill as close to the bottom as you can. If everything checks out I would believe you could then fill the holes with 5200 - There are a lot of people on here that know way more about this than I do, Hopefully they will chime in.
LK
