What is my gear ratio!?!? All data provided.
Skyhead22
Basics first. 1993 rinker captiva 186. Original 4.3 now has 5.0/lx. Sticker is missing from out drive that gives ratio. I only have the serial number 0F053311 which tells me it is an alpha 1 gen 2.
I have ran 2 props both stainless both 21" pitch.
Stiletto 21" 5200 rpmWOT 55mph per gps
Quicksilver Mirage 21" 5000 rpm 50mph (still pushes to 5200 rpm WOT)
Both tests 1/2 tank. Mirage prop done with 100 extra pounds in boat.
The first run with the stiletto prop figuring 1.61 ratio puts me at 14.87% prop slip. 1.81 would be 3.73% slip which is impossible. This particular prop is a bit worn as well.
The Mirage prop figures give me 8.98% slip with 1.81 ratio. This prop is really decent shape. It figures 19.04% slip at 1.61 ratio which is highly unlikely.
So I have two test runs with two props both suggesting two separate gear ratios. I really need to get this figured out so I can get the right prop on there to lower my rpm. I'm also a speed enthusiast and see no reason this can't be a 60mph boat being since I am underpropped as is. Mercury website suggest I use a 23" prop it will put me at 4800rpm WOT.
I am assuming it is the factory drive for the 4.3 and would like have the lower ratio of 1.81, please help! Thank you in advance.
Also, I have a concern of my tach being off, could this be likely? The boat was modified by an engine builder/ mechanic at a marine dealership I trust it is all put together as it should be.
Skyhead22
I put this in the props section because I need to figure out the best pitch of prop for my setup.
get a good shop tach to check your dash tach
mark the prop with a piece of tape, mark the crank pulley with a piece of tape. have someone watch the prop while you rotate the motor 10 times with the starter while the drive is in gear and the coil wire is pulled. count the number of prop revolutions.
steelespike
My info indicates the 4.3 190 is a 1.81ratio.the 205,210 and 220 and 5.0 220 are all 1.62.
Not sure what years these cover.
A 23" seems like a reasonable prop.
