What is normal RPM for a 4.3L?
NMBuzz
Can someone please direct me to a place where I can find the specs for a 4.3L Mercruiser- specifically what RPM's I should be turning at or near WOT.
(Currently at WOT RPM's are near 5,000 and the speed is near 40 MPH)
This seems to be too high of RPM's and I am always a little uneasy when running ANY machine WOT...
If I am off base on this, please let me know.
Thanks in advance!
Buzz
Re: What is normal RPM for a 4.3L?
adults only sticky, mercruiser manuals link
download the manual that pertains to your engine
specs are there
NMBuzz
specs are there
God I luv this forum! Thank you for that quick and informative reply!
Fun Times
Some where on the engine there should be if it is still stock, Or might be a sticker on the engine or flame arrestor that will tell you your max rpm for the engine.
dtime
5000 RPM :eek::not sure about the murcuriser but my 91 omc is rated at 42-4600 RPM WOT with a 2 barrel
dtime
ASfor the 40 mph i would try a different prop and lower youfr rpms you may be cavataing. i can reach 42 @ 3800 rpms with a 14.2X19 on my 19 foot thundercraft
NMBuzz
ASfor the 40 mph i would try a different prop and lower youfr rpms you may be cavataing. i can reach 42 @ 3800 rpms with a 14.2X19 on my 19 foot thundercraft[/QUOTE
The whole prop pitch and size thing just flat out confuses the crud outta me. I thought I was through with algebra in the 11th grade! LOL
Seems there has to be an easier way... I figure I am running about ~500 pounds give or take with fuel passengers, fuel, stuff... I may try to figure this out a little more... I would really like to get my RPM's down, but still have that good hole shot to get a skier up.
fuzzybob
You might want to do a forum jump over to the prop forum..... lots of prop gurus over there. They'll be glad to do the "algebra" for you.
dtime
try thishttp://www.propellerwizard.com/SITEPREVIEW/boat_props/index.php? web site
