What is the amp output of my 35 hp motor?
ablank
I have a 1991, 35 hp Force outboard. I have a two-battery bank connected with the recommend battery integrator (Newmar). When the integrator kicks charging power over to the auxiliary battery, it trips the fuse that is at the conection point of my wiring harness to all of my auxiliary devices. I can sit in the water for hours with no problem using lights, stereo, etc off of my auxiliary battery. But, as soon as I turn the engine over and start cruising, the auxiliary battery calls for power, switches the integrator and trips the fuse. I can reset the fuse, but it repeats. A local retailer told me to up-size the fuse on the auxiliary wiring harness, but to make sure that it is rated higher than the amp output of the motor. Is that a good idea? Why would a manufacturer of a universal wiring harness not rate it with high enough protection for a small outboard motor? Do I need a bigger fuse or is there an underlying problem that I haven't figured out yet?
Re: What is the amp output of my 35 hp motor?
Problem is not that the motor is supplying more amps than your fuse rating, but that what lies beyond the fuse is drawing more amps than the fuse rating.
The output is rated at a minimum 0.5 amps at 1800 rpm, and a maximum of 2.0 amps at 3500 rpm.
Because of the extremely low output of the charging system, your starting battery should be the only one connected to the system.
Your aux battery should be charged by an independent charger upon returning to dock or garage.
