what is the Oil drain plug washer size in a 2002 115 4 stroke efi?
Re: what is the Oil drain plug washer size in a 2002 115 4 stroke efi?
My neighbor's motor is a 4 cycle Merc 225. The drain plug was under the midsection cowling, which was plastic. You can match it up.
ingrams21
I know where it is but the problem is I am unable to get to the shop before they close so I am trying to get a size so I can get it from the local hardware store. Thanks for the quick response and help guys
