What is the pitch and diameter??
Deimus
I would like to know what the pitch and diameter of this prop is. quick silver # 4816316a519p
Is this a good prop?
Deimus
Re: What is the pitch and diameter??
same pic hows this?
WillyBWright
19 pitch. Not sure about diameter. That's easy enough to measure...from the center of the hole to the outer edge of a blade times two. 48-16316A5 ... the A5 has me scratching my head. It has all three blades. That's a good start. ;)
Deimus
it came off of a 140hp merc. will it fit on a 100hp merc?
Are these Both 6 cylinder In-line Outboards,..??..??....
Merc. uses the Same Spline count,+ Prop Shaft Lengths on All the larger Outboards,+ Outdrives,......
But,.......
There are Small Gearcase Diameters(4"),+ Large Gearcase Diameters(4, 1/2")..........
The Newer V-6 outboards,+ the Outdrives use the Larger Diameters,......
And the Older In-line Outboards,+ some of the newer smaller outboards use the Smaller Diameters.......
