What is this sensor above the oil filter 5.7gxi
Fireman78
i need to replace this sensor it is completely rusted. It’s located just above where the oil filter(or remote oil filter attachment) is. See the pictures
Lou C
Could be a knock sensor if your engine is set up to use one.
Ayuh,..... I believe that's an oil pressure port,...... knock sensors go in a water port,.....
I'm guessin' it's either an oil pressure sensor for a gauge,.....
Or,....
An oil pressure switch for an electric fuel pump,.....
