What is this?
apropes
New to boating and found this sensor (?) Located behind the starboard side panel. 2 wires that lead back to transom area.
Haven't traced the wires yet so thought I would ask this forum for their thoughts.
1995 Chris Craft 21' Concept bow rider with OMC sterndrive.20211206_174155.jpg
apropes
Thanks Scott! I'm removing that panel today and will know for sure. It is immediately above a cutout in the panel, so you may be right. I could definitely use more light there.
dwco5051
Like this one but in white trim
mike_i
I was also going to guess it's a light. Is there anything written or stamped on either side of it?
Horigan
That's a Courtesy light that lights the lower interior. There's one on each side. Should be a switch with that name on your panel. At least there is on my Concept.
crazy charlie
Courtesy light to typically light steps or stairs or floor,designed to light beneath the light only.Charlie
