what kind of glue ??
Psiclown
Re: what kind of glue ??
Any plastic safe super glue should do the trick. I used a cheap epoxy from Home Depot for the emblem on my truck grill. Plastic to plastic and never had an issue.
woosterken
ok ,thank you i thought supper glue mite be to thin
i dont have the wheel off to lay it flat
woosterken
Plastic Epoxy........ with that said. I am not fond of the loctite brand stuff and found the duro to be better. The plastic 2 part in the big syringe works great.
Woodonglass
I Agree wth Bob Duro Plastic Epoxy is the stuff to use. It is like WELDING for Plastic.
woosterken
ok ,thanks what i was looking for.
it is for the boat in my avatar which is all original, and i sure dont want to loose the little inserts,have no idea where i would find replacements.
do i put the glue on both parts of the wheel and the insert ,waite for it to flash and then press together, or just the wheel or the insert?
woosterken
Woodonglass
A LITTLE dab on BOTH and put together Immediately, tape it down overnight and your good to go.
