what kind of paint to use on the bottom of my fiberglass
fishskiff
72 bayliner goes on the trailer after each use so a good epoxy topside poly urethane is good enough right. thanks eat crab
Re: what kind of paint to use on the bottom of my fiberglass
Yes, that paint will work. Just do the proper prep. It's all in the prep.
"Epoxy Topside Poly Urethane"?? Do you mean Marine 1 part Polyurethane? 2 part epoxy paint? Epoxy barrior coat? something else?
Trailer Rollers and bunks are hard of paint. Pick a tough paint.
fishskiff
im thinking a 2 part epoxy poly urethane....? right?
I am not an expert, but I think it is either 2 part epoxy paint or a one or two part polyurethane paint. Awlgrip is pretty good. Perfection is pretty good. Brightside is 1 part and pretty good. Imron is real good, but not cheap and tricky to work with.
What kind of appearance do you want to achieve? Mirror finish requires a polyurethane.
