What material to bed an aluminum kicker bracket?
Trophy24
Hey guys,
I am about to install an OMC aluminum kicker motor bracket on my gel coated transom. What material should I use to bed the bolts and seal the bracket against the transom? I think 3M 5200 would be too permanent for my liking. Any ideas would be appreciated. Thanks8)
Re: What material to bed an aluminum kicker bracket?
4200 is removable. Are you intending on taking it off? 5200 will come off ...... with extra work.
Trophy24
:/ I guess I dont plan on taking it off. I know 5200 will be real permanent, but it will also not leak for sure! 5200 it is...
tashasdaddy
there's a guy on here that was talking about removing a tramsom plate that was embedded with 5200. pull the gel coat off. I'D 5200 around the bolts, 4200 embedded.
