what model is this bayliner
payton1803
just bought this boat to fix up, po didn't know what model # it is....23' bayler cuddy cabin 5.0 cobra outdrive.
hid #BPIEIICAB888 boat.jpg thanks
scott
jbcurt00
Re: what model is this bayliner
No title or registration?
Post 1984 Bayliner followed the HIN and manufacturer date code assignment like others manufacturers, the last 2#'s of the HIN the model year: 1988.
Looks like yours was built in February 1988 & released for sale as a 1988 model.
You can cross check the date here
payton1803
I ran the numbers from your link jbcurt , it says that CA denotes the model I am wondering what CA is, when I look for parts they want the model number ie..1950, or 2050 but I am not sure what it is
Teamster
My best guess is that the 1950 means 19.5 feet in length,..
And the 2050 means 20.5 feet in length,.........
zool
It looks like a Ciera, which may be the CA...but i dont recognize the side cabin window confic..
jbcurt00
Look for info online for 1988 models. You should be able to find at least 1 to compare to yours.
Bayliner can't supply the model # if you have the serial #: EIICA and have the HIN Manufacture date & model year?
Unless you typed the HIN inaccurately: BPIEIICAB888
I find that hard to believe. A Bayliner dealer (or whoever you're asking for parts from, unless it's via the internet only) should be able to provide that info for you.
If not, contact Bayliner directly via email or phone: (360) 435-8957
Via email, they ask for the HIN on the form
[h=1](360) 435-8957(360) 435-8957[/h](360) 435-8957[h=1](360) 435-8957[/h]
jbcurt00
If the link I posted isn't the correct Bayliner decoder, I may be wrong, but per that info, the CA isn't a model designation, it's part of the serial #.
Did they make more then 17576 (maiximum # of possible serial #'s w/ 3 letters, using a 26 letter alphabet, cubed) of your boat in 1988?
If so, then the model wouldn't be a portion of the serial #, they'd need the extra digits as part of the serial#. If they didn't, then perhaps it is the model #.
And 1950, could be anything greater then 19' and shorter then 20', boat manufacturer's clearly can't read an english or a metric tape measure.... May be more accurate now. 'Newest' boat in my fleet is at least 35yrs old, probably older.
payton1803
has capri emblems on it that look original but maybe they are not?
jbcurt00
No, they probably are
Capri emblems are on the boat? Yeah, that's kinda important info
payton1803
mine looks just like that zool just bigger and had a 5.7 in it ( now it has a built 69 327 ) this is my first go around with a boat, been building cars and 4x4 trucks for years so its a learning experience
scott
looking to get a new mooring cover or a camper top, and they keep asking for the model # that is why I am looking for it
