What oil filter do I need?
sikz3
I will be changing the oil on my 2004 Bayliner 185. I need to know which filter I can get at my local auto parts store that will work with my 4.3l vortec v-6 190hp.
achris
More fish than mountain goat
Re: What oil filter do I need?
You got a remote oil filter or the standard 'impossible to access' unit?
matt167
Could probably use the same filter your Bravada takes unless it's a remote filter, even then most of them copy the original oil filter threads.
Do you have the remote oil filter or the block mounted oil filter. They are different on a V6.
Engine filter is the same as the automotive version for a 4.3, the remote is the same as a 5.7 V8 automotive filter.
sikz3
No remote filter. I wish. Most years are the same then?
