what oil goes in my power trim?
cisnet
Just wondering what oil to replace in my power trim? can i use power steering fluid or is there a special oil?
Re: what oil goes in my power trim?
You might advise on the year and HP of your motor. Most modern PTT units use Dextron III ATF.
Susquehanna Squid
Probably Dextron but I had to use hydraulic jack fluid (I had nothing else)in mine and it works just fine.
ezeke
GM Dextron II or OMC/BRP Power Trim/Tilt & Steering Fluid - Part # 775612.
