what prop for carver cruiser 2667 ?
bigdave438
hi to all.......first time boat owner,im a proud new owner of a 1982 carver santa cruz 2667, 260 mercruiser..WOT 4200-4800,,,5400lbs.....engine repowered last year. out drive i believe is an ALPHA ONE, correct me if i am wrong about the out drive. i just took the boat outta the water today (salt water) and i am in need of a new prop. 15 3/4 x 16p is what i got from carver yacht. what manufacturer would work best with my boat......
dan t.
Re: best prop for carver cruiser.
You might want to try a merc #48-16440-16, this is a 16x16 wide blade prop that works very well with a heavy boat , it will give a good hole shot and gives stern lift, adding some extra cup makes it even better.
i dont want to buy the wrong prop..
Ayuh,... What were the actual rpms at wot with the prop On it, rather than what it's Supposed to run,..??
You probably want another copy of what's already there...
bigdave438
Thanks for your input..i will look into that once i get outta work.....
bigdave438
i never got to run it wide open, i just bought the boat in july...the prop was already bad. i waited for this day once the boat was pulled out to buy a new prop...i keep my RPM's at 2000..i got bad cavitation @ 2400 RPM so i kept it at 2000 to stay safe....engine runs strong.....the prop has a very bad blade on it...the blade was eaten away cause of the inproper ground...
