What prop on Regal 1900 4.3 gxi
Regal LE
Be interested to know what others using on this boat mainly for water sports not too concerned about top speed want best low end 3 or 4 blade and pitch. ?? Currently using Pro Tech 4 blade 20” hits 5000rpm at wot lightly loaded full up trim bottom end could be better
you are propped correctly for top end RPM loading
if you want more hole shot, drop down in pitch and watch your RPMS more closely
however to fully answer your question, you should post all the information that is required to answer prop questions. (hint------ its in the stickies at the top of the forum)
