What regular main is needed on 1982 70hp Johnson
Bradg
I would like to know what regular maintenance is needed for my 1982 70hp johnson? I have only owned it for 1 1/2 years it has been winterized in fall after both summers used. The only problem it has had<br />to this point is the power pack, had to be replaced<br />when there was no spark on one cyl. The motor is mainly used to pull kids on tubes.
dolluper
Re: What regular main is needed on 1982 70hp Johnson
Change lower end oil ,spark plugs ,look for corroated grounds, charge battery ,look for loose connections,and so on
Cricket Too
It wouldn't hurt to decarb it a couple of times every spring also. Also install a fuel/water separator if there isn't already one, if there is, then change the filter every spring. Good luck. P.S. When you change that lower unti oil, make sure you change both gaskets around the fill and drain plugs to keep water out, it's worth the 20 cents they cost.
Solittle
Change the water pump every couple of years and I would do the thermostat at least once. Pull the prop once a year & grease the splines & hit all of the grease fittings including the steering cable. Also just for looks give it a good coat of wax.<br /><br />Don't forget the trailer especially the wheel bearings.
ledgefinder
Ensign
Drain the carbs (easy to do on that motor), then crank it for ten seconds or so with the choke on to pull any gas out of the low-speed circuits.<br /><br />Replace the water pump impeller unless you're sure it's just been done. Check that the hot horn working.<br /><br />Drain & refill the LU fluid at the end of the season, so any water in the LU won't freeze and crack the casting.<br /><br />Those are good motors. The weak spot appears to be cooking a cylinder, generally the middle one. Overheating on a two-stroke can occur due to lean mixture or too much timing advance (amongst other reasons). A clogged main jet will let that one cylinder run lean - that's why you want to run fresh, non-gummy gas. Draining the carbs at the end of the season keeps the mains from clogging with gummy gas. There are (if I remember right) service bulletins describing richening the jet on that middle cylinder, and backing off the WOT timing a couple degrees.<br /><br />Keep the engine from full-throttle lugging. Prop it for 6000 with a light load. Decarb if it hasn't been done in a while.
Bradg
Plugs and lower unit oil have been change. carbs have been drained and prop was removed and greased<br />also all other grease fittings. Battery is out of boat and charged. Boat has been polished and trailer wheel bearings repacked before boat stored. I will look into fuel/water separator,thermostat, and water<br />pump next season when pulled out of storage.<br /><br />Thanks for the help
