What should I check on OMC Sterndrive?
s_explore
Hello guys, I have an OMC 305 engine with sterndrive.
I want to ask you guys what should I check in the gimbal housing and drive for reparation. I have them removed from the boat. I know on the gimbal housing I should replace the bearing with bellows, but should I replace something else? Same thing for the drive should I check/replace something before putting it back in the boat.
Thanks,
Sam
88 Capri (2022 SOTY)
Not saying yours will need these but I needed to change the steering bushings and seals on the top and bottom of the transom housing(where it swivels).
I had alot of back and forth play on mine, but like Kenny said a genuine manual is a must.
I found mine on a free download site but due to rules I can't post the link.
Thanks,
Sam
Ayuh,...... Which, OMC outdrive,..??
