What should my WOT rpm range be
Smurph
My engine is a 1989 Mercury ( C123216 ** 70 HP ELPTO. I noticed that when hitting WOT, and I only did it once for like, 5 seconds max., it climbed to 5800 then I pulled back. Pretty sure that was going to be it, but didn't want to push it. I had read somewhere that my WOT should be around the 5250 mark on rpm gauge. It's a pontoon boat, 1989 Party Barge, and don't know the prop size yet, just looking for max rpm numbers. Can anyone share what they know please, and thanks.
Alumarine
I think there should be a 0 in front of that serial number.
If so, and it's a 3 cylinder you're right, WOT is 4750-5250.
Did you test it with a normal load or a light load?
You would want it to be able to rev at the high end of WOT with a normal load.
Smurph
Thank you Marc for responding. I put some photos of my boats in my profile, including the serial number on engine block freeze plug, and no zero, just starts with a C, as pictured. It is a 3 cylinder as you said. As for the load, I guess I'd have to call it light, as it was just me and the wife, and my normal gear, life jackets - anchor - tool kit - and fuel. Being that I don't have passengers aboard, would that be considered a light load?
I would imagine if I had a few passengers on board, it possibly I guess could drop it down to the 5250 range. Only one way to see, and that's load it down and see. For now, I'm just not pushing it past the 5250 mark to save the old motor. It's a noisy thing to me. I've never had a pontoon that didn't have a seat over the top of the engine, blocking some of the engine noise, and as the pictures will show, its just wide open for noise to spread. I bought it last year at end of summer from the original owner. I had to replace coils and ignition wires, cleaned the carb system just by de-carb method, but it now runs like a champ. My prop has a few minor chips and dings, so I plan on replacing it next year, that's when I will make the move probably up a pitch or so if needed. If as you said me and the wife and gear is considered a normal load in your opinion, I think I need to move up a pitch, don't you? Thanks.
Alumarine
By normal I meant the load you normally carry or the activities you do (ie tubing) say 80% of the time.
