What size seals do I need for bearing repack?
randyo
I went to the automotive shop the other week to pick up a pair of "Double lip" seals in order to repack my bearings. The guy at the counter said they have many sizes and asked me which one I need. How can I find out without taking the bearings apart? I have a 1997 single axle zeman trailer.<br /><br />Also, I believe there is a cotter pin I will need to replace too when repacking the bearings-- what size cotter pins should I pick up? Anything else that might be size/type specific? Thanks very much!
tommays
Re: What size seals do I need for bearing repack?
you might have ? really<br /><br /> the most common is 1-1/16 outer with a 1-3/8 inner with a coupple of different seal OD,s <br /><br />but there is no standard so the only way to be sure is to listen to the parts guy and take it apart<br /><br />after that keep it written down and you wont have to worry again<br /><br />tommays
Moody Blue
If you don't want to take apart the hub first to determine what parts are needed, why not contact the mfr and get the specs from them ? As tommays pointed out, there are several different sizes but not a standard.
Ayuh,........... I Agree........<br /><br />The Only way to Know for Sure is to take it apart,+ Check the Part #s,..... <br />All the Bearings,+ Seals will have the #s printed/stamped on them.............<br /><br />Cotter Pins on the other hand Are Standardized...........<br /><br />1/8th"X 2"s will get the job done.......
