What tilt and trim trim other years or models will fit 73 50 hp
Texas Prowler
As the title states... Are there any factory units that will fit? I'd like to keep the outboard close to the transom as possible. If I absolutely have to I'll look into aftermarket units.
Thanks!
flyingscott
I am not even sure that motor came with one. If it did it is rare and expensive and parts are mostly NLA. If it was me I would look aftermarket the CMC PT130 is a good unit
emdsapmgr
Flying is correct. In 73, the 50 hp models had an available (dealer installed) power tilt kit. This did not include power trim. They made one for the short shaft model and another for the long shaft models.
Texas Prowler
Well i guess I'll just have to go the aftermarket route. Probably best anyhow seeing as it would come Roth a warranty and replacement parts are readily available.
Watermann
My 1977 55 HP Johnny came with the tilt only and there was no TnT option so I went with the CMC PT130. It really is a nice unit and the set back wasn't a problem on my 16' boat. Your steering torque will vanish being able to trim the motor up and add safety for your prop when coming into shallow water to beach or load.
