What timing light to use
PitchFork
I have a 1994 GM 305 with Thunderbolt 4 and need to check the timing before and after I remove and replace gasket on the distributor due to an oil leak around it. What timing light do I need: just a plain Inductive Light or one with Advanced Timing Check?
Thanks in Advance
Re: What timing light to use
Ayuh,... Either will work, Just Fine...
