What type motor oil for 3.0L? Please help
Status
Not open for further replies.
Glassport from Newport
Re: What type motor oil for 3.0L? Please help
My 1988 Mercruiser 3.0 says to use 10w30. I've been using Penzoil Full Synthetic 10W30. Do you think the Fc-w label matters if you're using synthetic? The point of using synthetic is to keep the oil from breaking down.
Where does it say that?????????
I have never seen Merc recommend 10W30 except in the trim pump. Maybe back in the early 70's , but not in the 80's on newer.
Alumarine
Not even in the early 70's either, according to my operation manual.
They just recomended straight weight 20, 30 or 40 depending on the temperature.
The oil cap on my engine says 10W30. There is nothing on the cap that says Mercruiser or any other name, so it may not be the original. I don't know what the original would look like since this is my first boat and it didn't run when I bought it (cracked block).
Rocky_Road
Someone slapped an automotive oil cap on your engine...ignore the writing!
Go by the Mercury chart in the second post of this thread. This is the latest recommendation for all Mercruisers...regardless of age. The chart takes into account all of the oil formulation improvements that weren't even dreamed of when your engine was assembled.
Status
