What type of anchor and chain or rope
Metabo
As I'm relatively new to this type of boat, I have a few questions about anchors and chain versus rope.
I will be using this boat on the St Croix river in WI and also the Mississippi. I plan on staying over night on the boat from time to time and was wondering what type of anchor and what size rope I should use with this boat.
1977 Sea Ray SRV 220 Overhighter
Metabo
  • Original Brochure.pdf
coastalrichard
Re: What type of anchor and chain or rope
Metabo, for a boat your size and weight, I would think something at least 15#-19# would suffice. Probably a hooker style that will catch the muddy bottoms where you'll be. As for the chain, at least ten feet of 5/16". The rope should be at least 1/2" (I prefer braided) to 5/8". Get enough rope to allow a rode of 7x your average depth. You ought to consider a second stern anchor for those times you need to overcome current and the constant back and forth caused by the wind. Good Luck!
Metabo
Thanks for the info Rich
Metabo
Metabo
So, the chain would hook to the anchor and then the rope to the chain? Do I really need chain? Don't want to mark up the boat when dropping the anchor.
Metabo
coastalrichard
Anchor, chain then rope. The chain is, perhaps, the MOST important part of the mix...it lays flat allowing the anchor flukes to dig into the bottom (the rope tends to float toward the surface). With no chain, you might just as well throw out a mushroom and get drug around by the currents and winds. As far as marking up the boat, Elmer Fudd would say...be vewy, vewy careful:eek:
Metabo
Thanks for the explanation. Now I get it! As I've not picked up the boat yet, it may have that type of set up, I just don't know yet. It was always used on a lake, so it may just have a rope and anchor. I sure like the forum here at iboats, always good info with some humor.
Metabo
Captain Caveman
You'd want to use a chain even when anchored on a lake, on the moon, or in a river. When I pull up anchor the rope rubs against the rubber rail on my boat. When I can tell that the anchor is getting close to the surface, I pay a little more attention and pull straight up so that the chain doesn't scuff the boat. It's barely even something that I notice as an extra step or inconvenience.
coastalrichard gave you good advice. Mine will be to follow it and not skimp on the length or thickness of the rope. The last thing you want is to be sleeping in your boat when the wind kicks up, and wondering if the anchor/rope is going to hold!
spoilsofwar
They make everything vinyl coated if you want; chains, anchors... No need to worry about marking up anything as long as you're not being reckless.
oregoncruiser
I took a section of 1" wildland firefighting hose and covered my chain and all fittings with it. prior to working the chain through the hose, I used red hot punch and melted holes every 6" through the hose in order to allow water to drain. My anchor is the only uncovered object that gets near my boat. It also protects the the anchor locker while it rides around on the lake.
Just an idea!! I could take a couple pics if you don't follow what I'm describing.
Metabo
Wow! All good advice. Thanks everyone.
Metabo
Metabo
Metabo
I bought a 'Digger Anchor' they are made in MN and they are designed to work without a chain. I also picked up 100 ft of 5/8" rope. Again, thanks for all the advise
Metabo
OllieC
I need one too - The anchor looks cool.....
