What type of oil for the lower unit?
t_south91
Hey guys,
Got a question and I have looked around and just can't figure out the answer. I have a 1985 OMC 3.8l 4 barrel with a stringer 800 outdrive.
I went ahead and checked the oil on the lower unit ( or in my terms "the one with the drain plug all the way on the bottom close to the fin") and it needs to be changed. Any recommendations on what to use??
Thanks a lot for the help guys!
southkogs
Whatever gear lube the local marine shop, Wally-world, or other fine retailer has available will probably do. Most would likely suggest 80W90. You don't need type C in yours.
