What type of steering cables do I need?
sleekpete
I just bought a 1976 glastron gt 150 and the steering on it is really hard. When I go yo teleflex, what type of steering cables should I get? I have a 1975 johnson 75 hp outboard on it, if that helps.
Re: What type of steering cables do I need?
Ayuh,... Not sure I understand the question Pete,...
You choose which helm you want, the length of cable required,+ the hardware to attach your motor...
The NFB helms are nice, but require slightly more effort to steer... Probably worth it though..
That little boat will do Ok with the 3-turn, rather than the 4-turm helm I would think...
Good Luck..
mortaz
You have to do same troubleshooting its maybe not the steering unit or cable
Remove the bolt from the end of the cable and turn the o/b by hand
