What weight of oil should I use?
Status
Not open for further replies.
m_sherman211
What kind of oil should I use in my boat? Its a Liberator with a chevy 350.
I've been told to use sae30 and 25w40.
I have no clue on what weight and brand. Any suggestions on what works best?
Re: What weight of oil should I use?
Ayuh,... Do a search for Oil,... You can run ANY Oil ya whata run, Period....
I run Mobil 1, 15W-50...
Alpheus
No,No,No!!!
You must run exactly what the manufacture says to use. If you do not pay for the high dollar oil that the manufacture says to use, your engine will seize up as soon as you turn the key. You have been warned... :rolleyes: :rolleyes: :rolleyes:
Status
