What would you do?
wildracing22
I am in the unfortunate event that my engine needs pulled, the engine seems to run extremely smoothly and starts well. I am wondering though should I have anything else tended to since the cost would be less now?
The boat is a 98 model, with the 350 mag mpi, and bravo 3 drive. I am not looking to spend more money, though if it makes sense to do something while its out I will.
Any advice will be greatly appreciated.
Re: What would you do?
Ayuh,.... I'd do a visual of everything along the way,...
hoses, wiring, pretty much everything...
Replace what needs replacin'....
The motor probably don't have near enough hours for a freshening...
Why ya pullin' it,..??
muc
Depending on how accessible these are when engine is out of boat vs. in the boat.
Have your starter rebuilt
Replace bilge pump
Disassemble cool fuel and check filter screen, renew heat paste
Check coupler
Good Luck Muc
