What year Force and most common cause for overheating
Dude
Please tell me the year of my Force and what is the most common cause of this motor to overheat? Thanks
9.9hp OE 090571
Re: What year Force and most common cause for overheating
Should be a 1994 give or take a year.
Most common causes of overheating:
Worn out impeller.
Bad thermostat.
Lack of oil in the fuel.
Dude
Thanks roscoe, I can't find a t-stat is there a t-stat?
Thermostat is not located on the powerhead, like on most outboards.
Thermostat is located on the back side of the mid section.
Here is a picture.
All parts available from any Mercury dealer, or online from mercruiserparts dot com
Dude
I'll check the t-stat. Thanks Rosco for your help.
Dude
Roscoe, I found the t-stat and removed it and the engine still get too hot to the touch. A water pump is on order.
Having replaced a number of water pumps I would imagine the one should not be difficult. Thanks
