Whats in the hull and aft section of my boat?
watermellon1
can anyone tell me wht happened to glasstream boats? I have just bought a used one from a friend, got a great deal on a 19' cuddy i/o merc 3L and I want to find out what's in the hull and transom area of the boat, someone guessing said sand
Re: Whats in the hull and aft section of my boat?
Well,...... Your Question is somewhat Vague,.... But I Doubt there's much Sand.....
Where,.. Exactly are you talking about,..??.....
steelespike
more than likely if you feel there is some thing in there it is water.possibly absorbed in the floatation foam uinder the floor.Give us some details of your question.
watermellon1
:} ok sorry guys, i guess all us newbies (to this site) tend to forget you cant see the dang boat...
it is a 19 foot glasstream is very heavy and tends to handle water well, the areas I m talkin about are port and starboard sides of the engine well about 2 feet from engine well outwards to side of boat on port and starboard sides. the fiberglass seems to be filled with something that makes the back corners of the boat solid it runs from the middle of the boat to the stern. if you rap on the outside of the boat at the back it is solid sounding it is like that forward of the passenger area up front on both sides as well. in the middle it sounds hollow where the passenger compartment and helm are located
Filled with floatation foam.
Only inspection will tell you if it has absorbed water.
It is not filled with sand.
watermellon1
So shall I take a peak? Now Im curious and tht usually leads to trouble, I m pretty handy, just put a thru hull transducer in, so do I need to tap into these areas a little and see? I would goin from inside the boat as small as I could andthen be ready to patch with fiberglass afterwords
watermellon1
also where would I get some specs on this boat, as far as what it should weigh, this would tell me if need to tap into anything right?
If you can provide the exact year and model of the boat, someone may be able to provide the dry weight.
Take the dry weight, ad the weight of the fuel, batteries, water, gear, and trailer. Compare that number to the actual weight obtained on a scale.
The hard part is determining the weight of the trailer and the miscellaneous gear.
Scales are available at truck stops, feed mills, scrap yards, and moving companies.
For example, a 1986 Glasstream 192 B/R with the 120 hp engine, weighs 2025#.
A 1986 Glasstream 192 C/C with the 120 hp engine, weighs 2100#.
Texasmark
Transom, plywood or composite?
1. Easy test: look up under the deck at the top of and upper sides of the transom. Somewhere around back there you surely will find a corner exposed where you can determine the material type. A flashlight and 1" inspection mirror will work nicely.
2. Harder test: Getting as high as is practical, on the inside of the transom, drill a small hole not over 1" deep. Observe the material that comes out on the bit for your answer. Also, if composite you may find the drill drives at different rates of depth penetration (especially if a framework with foam fill), where plywood would be steady and uniform. When finished, RTV or epoxy over the hole.
Stringers?
Usually covered so you can't see inside but the drill test works there also.
Floatation absorption Question?
Weighing can be misleading as there are so many variables to consider. What you might do instead, is to look in the bilge for water marks. If your boat has been sitting with water in the bilge you can surely tell and tell how deep it was. If no water marks (to speak of) don't worry about rot and saturation.
Most people store their boats with the drain plug removed unless they are stored in the water. So the opportunity for soaked floatation is nhil; plus there is open cell (polyurethane) and closed cell (styrofoam..like hot drink cups) types of floatation that may or may not absorb if exposed (styrofoam surely not). I have had boats with both types. Sometimes, if the poly is exposed it is painted over to seal it. Styrofoam was laid in in sheets and the other was sprayed through holes in the deck then the holes sealed.
Last test: You can look at the boat and get a feel if it is heavy by design or light and nimble. Hull is easy to test; deep V or flat bottom? Take your knuckle and tap all over the hull and sides.....you can tell the difference between reinforced and non. Reinforced obviously weighs more; thick hull same thing.
After that assessment, how does it behave on the water. If it is the light and nimble type and plows through the water like a lead sled, then you may have a problem with floatation saturation. On a heavy design it would be harder to tell.
Stringers, if bad will allow the deck to flex as you motor along. BTDT.....thank goodness in someone elses boats.
Transom, if bad can usually be observed by stress marks around engine mounting cutout and by deflection during acceleration. Have someone else at the helm, you watching the transom right where the engine is mounted. Have them hammer out of the hole...full throttle. Does the transom flex? If not, quit worrying. If so, find out why.
HTH,
Mark
