Where are my freeze plugs.
prayingmantis
I have a 95 mercury marine force 120 outboard. The I'd plate is blank. I'm looking for the freeze plug for the serial number. I've looked and cant find it anywhere. Thank for any help
Nordin
There is no freeze plug on these outboards.
It should have a ID tag at the transom clamp but it can be gone, there also should be a cast circle stamp at the power head.
The year is in the middle of these cast stamp but no serial number.
jerryjerry05
If the motor and boat are a combo from the factory?
You can send the hull ID# to the manufacturer and they can give you the serial #
Force blocks have a foundry stamp, usually under the coils/packs or under the
bottom carb.
Like Nordin said it's usually a circle with the year being in the center.
But no serial # just the year.
